Truma Water Pump Faulty??
Sep 8, 2006
293
Hi.
We've just had our 3rd outing in our Series 5 Bailey Ranger. On our 1st and 2nd outing we primed the water system and filled the hot tank etc and the water pump shut-off. When we turned on a tap the pump would make a "dugga-dugga-dugga" sound as it pumped water through and for a second or 2 after the tap was closed. This all seemed perfectly normal.
However, this time out we primed etc but the pump never made the usual sound but just a faint buzzing sound constantly. I tried allsorts but this stayed like this all weekend. Wether the taps were open or closed it would buzz and the red light on the switch would stay lit. The water pressure was fine. I ended up turning the pump off when not in use. Is this normal or has anyone else had a similar problem?
Thanks, Dan.
