- Mar 14, 2005
- 18,720
- 3,962
- 50,935
Hello Surfer,
I hope you had a good Christmas. Mine was fine and as I was driving I avoided alcohol, so my mind is as sharp as ever.
I don't like trivialising subjects like this as they are a matter of law and we should all try to comply.
Let me be clear, in your opening posting you provided a link to
http://www.amazon.co.uk/Reich-Towbar-Load-Control/dp/B003DOCHYC
This is the Towbar Load Control, by Reich part number 127499.
The description makes no differentiation between it suitability for SA or TA trailers, thus as you pointed to it, it was reasonable to assume your posting was about this specific model.
I was not aware that Reich offered a model designed with TA's in mind, and as yet I have been unable to find any technical information about it, I cannot comment about how or if it can adequately compensate for the noseweight/height issues. though I am very sceptical about how the device can automatically compensate for factors such as suspension compliance, vertical height of CoG level lengths of hitch to both axles, etc. What is clear is that Reich do recognise that TA's represent a more difficult set of criteria to SA as far as noseweight is concerned.
It is interesting to note the comments regarding the C&CC nose gauge comparison tests. Whilst I have not seen the actual report, to read of 6 to 10Kg errors is not surprising, considering the additional height the device gives.
The other fallacy that often arises regarding gauges and meters is that Digital devices will often assumed to be "more accurate" This is far from the truth, and just because something is digital does not necessarily make it better or more accurate. I could go into a lot of detail about analogue vs digital measurement, but that is a whole topic on its own.
The fundamental fact remains that the legal noseweight measurement is to be carried out with the trailer hitch at the same height as its actual towing height - not with the trailer simply level.
