Tyre Size
Andrew
I can not help with the size of your tyres as it is on the sidewall should look like this 135x15R allso the pressure it is vital that this is correct for safe running.
If you requier replacements, they must be 8ply which is for caravans cars are 4/5 ply and are not suitable. any caravan dealer will supply and fit.
Any thing else on tyres come back.
Hope this helps
Jim m
Andrew
Hope this helps
Jim m
see here for tyre information
http://www.tyreline.com/wheel_tyre_info/tyre_markings.htm
Avoid caravan dealers, they'll charge the earth and they really don't know what they're talking about.
You'll need to know the size of the tyres eg 195/70 x 14 AND the MTPLM of the caravan. Ring round tyre outlets, tell them it's for a caravan, quote the size and weight, and they'll help you out.
I used www.tyretraders.com - you have to remember to add the fitting charge but they're still cheaper than most other places.
Hankook tyres have a poor reputation for blow-outs on caravans so best to avoid them.
Your caravan was probably fitted with 185/13 8ply tyres.Ring round your local tyre dealers and see whos cheapist.Dont worry about wear as they will crack before they wear out.
got this of other forum
Load Index.
A tyre is designed to carry a specific load or weight, an overloaded tyre will quickly overheat and the risk of puncture
increases accordingly. For single axle caravans it seems hardly worth mentioning the importance of avoiding punctures.
The Load Index is shown large on the tyre wall immediately behind the size coding and in front of the speed letter code.
A typical example will be:- 165/70/R/13 79T.
165/70 is the tyre width and height ratio in millimetres.
R indicates a radial type construction
13 is the wheel diameter in inches
79 is the Load Index
T is the speed code.
To be legal, and safe, a single axle caravan must have tyres designated as suitable to carry at least half of the maximum
allowable weight or Technically Permissible Laden Mass (MTPLM). The Load Index number represents the tyre maximum
weight limit in kilograms. A pair of tyres index coded 79 may not used on a caravan having a MTPLM in excess of 874 kg.
Load Index Chart
Index kg Index kg Index kg Index kg
60 250 76 400 92 630 107 975
61 257 77 412 93 650 108 1000
62 265 78 425 94 670 109 1030
63 272 79 437 95 690 111 1090
64 280 80 450 96 710 112 1120
65 290 81 462 97 730 113 1150
66 300 82 475 98 750 114 1180
67 307 83 487 99 775 115 1215
68 315 84 500 100 800 116 1250
69 325 85 515 101 825 117 1285
71 345 86 530 102 850 118 1320
72 355 87 545 103 875 119 1360
73 365 88 560 104 900 120 1400
74 375 89 580 105 925 121 1450
75 387 91 615 106 950 122 1500
