This must be one of the simplest devices to fit and then use, great little unit for showing the tyre pressure and temp.
Once the monitor device is charged it lasts 60 hours apparently, which communicates with all the 4 x pre registered tyre sensors.
No need to change any settings, High Temp is set to 70, high pressure is set to 44 and low pressure set at 29. Units are in degrees celsius and psi
Although I’ve not fully tested it, I do highly recommend the ease of set up and fitting.
