That is a good idea..The only problem is US !! If we do not look often enough or carefully enough we could miss the puncture but it costs nothing to do and is a good thing to train yourself to do anyway... As I said the technology needs to be 100% before I trust it without Bands but every thing you can do to stop running on flat tyres and wrecking the tyre is a plus.It's also a good idea to adjust your mirrors so that you can check out the caravan tyres when you look behind you.
Robert
I have a very different background to 99% of people here so I am coming at the problem from prevention. I have been working with data logging experts and most serious teams who race endurance raceing cars and bikes use pressure sensors, the only time they get problems is when a driver ignores the warning or has to travel to far on a tyre which is not designed for puncture resistance and have been punctured with carbon fibre fragments and de-laminates (this is the most spectacular type you see on TV). The sensor system used on the bikes we race has been 100% over the past 3 years and has stopped some possible serious injuries to the riders we support.I'm not saying for a minute that pressures sensors would not prevent a blowout, but not many people, actually I don't know anyone, have this system. The point I picked up on is the fact that a tyre deflating slowly while travelling at speed is exactly what causes tyre failure. I agree that tyrons are a last defense but for most, their only defense. I presume when you say for you a blowout will never happen you mean you use the pressure sensors? By the way, both times I've had a blowout was at sensible speed on tyres with less than 1000mls wear. In the first case the sidewall showed some signs of savaging, in the second there was not enough tyre left to tell. What I would say is no system is 100% reliable.
