Ultima 260
Have had one of these on order from local dealer for a little over five weeks now. Dealer says that "rep" visited last friday and said there were none in the country. Any one know differently ?
I'm told that the Ultima 260 has a better or stronger pole system to thers with a similar name, is that true ?
Sep 26, 2006
153
Neil, according to Google there is no such awning as an Optima 260 (althought it's a possibility it didn't pick it up) so it's probably more likely it's an Ultima 260. If you paid a lot more than that is there a possibility you have ordered the 390 which is the three section awning?
If you're unsure as to availability there were up to 30 or 40 of the 260's available with a lower price on ebay last week because I was looking at them. One sold for
Mar 15, 2006
713
Hi Neil
How did you get on with your delivery of the porch awning?
I have just saw a 260 Burgundy UlTIMATE PORCH for sale in the free ads in Gwent for
Mar 15, 2006
713
Hi Andrew
That is where we had our 390 from, much cheaper than any where else at the time.
We upgarded from the 260 after only using it for a weekend, the 260 was nearly the same price from the other dealer as we paid for 390 from the site you mentioned.
Allyson
I'm told that the new version expected in the counrty very soon is quite a different model with stronger material and upgraded poles,but hence the hike in price
Jan 2, 2007
92
Does the stronger material and upgraded poles mean that it will not be as light? Do you know if it is possible to see the new one online anywhere as I was just about to place an order for a 260 but now wonder what the new version is like?
when i ordered it (without paying for it) my local dealer said that the poles are stronger and don't flex as much and that the material was of a superior quality.
After waiting five weeks now i'm told they are expected any time.
Mar 19, 2007
39
We purchased a Ultima 260 last year from Awnings Direct and they were very prompt with delivery. We were also very impressed with the 260 as a weekend awning as it is very easy to erect, and fairly light. It also comes in a bag which I have so far been able to get it back into. Not sure what needs upgrading as we have had no problems and it has been exposed to some fairly high winds with no trouble. We certainly recommend it.
Well they've finally arrived and my dealer very kindly rang to say the new stock of improved 260's has arrived and they have kepta blue one asside for me. I did order a green one because i was instructed to! No green ones in the country, i'm told the rep says "no". So its either blue or Burgundy !
Has anyone got a new stock Ultima 260 in green ??????
Dec 23, 2005
326
I'm thinking of trading up from a Scenic Plus awning to the Ultimia 260 or even 390.
Does the awning rail have to be perfectly straight for the Ultima awnings? Would there be any issues if the rail wasn't straight?
Mar 7, 2006
562
WE HAVE GREEN. From Awnings.co.uk
Used it 1st time last weekend. perfect and looks very stylish. Item was delivered in about 3 days. fab awning.
Hi Martin,
I have just received Ultima porch 260 awning from Awnings Direct
The assy instructions under pitching read as follows:-
The Ultma should be positioned on the caravan so that the beading is horizontal. The beading should not slope, as it will not be possible to get a satisfactory result.
The actual length of the awning is 260cm so if you caravan roof has a straight length of 260cm you should be okay.
Trust this info is helpfull
Royston
May 3, 2006
77
Hi
We have just purchased the Ultima 390. how does the front of the awning seal to the van, I beleave it is straight at both ends. My van is straight at the back and the awning will finish before the front slope. Is there a special seal?
Regards
Leso
May 3, 2006
77
Hi
Regards
Leso
I should hav said "BELIEVE"
HEY HEY ! Just had a phone call from our friendly dealer to say that the green 260 that he couldn't get, (so i had to have a blue one), well he's now got a green one ...Brill !
So i'll have a trial run on Saturday and if i get in a pickle i'll be on the forum !
Dec 23, 2005
326
Thanks for the comments. It looks like that the Ultima 390 might be too long for the Ranger as the awning rail slopes down towards the front. As we are thinking of changing the van next year, I might just put up with a 'wonky' awning for a year.
Mar 15, 2006
713
Leso
The front sides nor the back sides do not fit to anything, you have to pull them down very tight and you peg very tight to the van.
I see that one of the porch awnings I think it is a Bradcott porch awning had padded edging to give more of a seal.
Hope this helps.
Allyson
