Unhitching! What am i doing wrong please?
A tip I was given (although not fully covering your ssituation) was on arrival at campsite when stopping to book in release the stabilser ,the van will not come off when you drive to your pitch the stabiliser will by that time release and should come off straight away.This has worked for me for past 4 years on both Alko and Winterhoff stablisers
Hi Rambler, sound bit of advice, do you know if it would work with the separate leaf stabaliser (Bulldog), I do have an alko chassis but as the van is a 95 model it hasnt got the built in stabiliser and yes I have the unhitching problem.
Hi Gagakev
Do not think it would help you as with the built in stabiliser all you are doing is releasing the stabiliser the van is still firmly attached to the tow ball,In essence I am moving the van and in doing so it pushes the friction pads back off the ball.Would suggest that you probabley have a problem with the tow ball try vleaning it up to make it shiny and malke sure there is no paint or other material on it
Cheers hope this helps
Thanks Rambler will give it a jolly good clean before the next outing.
On that note though as it is the older type it is smoothered in grease
Maybe a bit of debris in the grease ? So clean it all off and use fresh.
Forest, Thanks for telling me I have a front bearing/pad in head
Sorry if daft question but is that on the hitch or are you referring to the
stabiliser pads, which would not effect it.
Due for service before Easter, so if the hitch will get it checked by the engineer
before our next venture.
Thanks Chaps
Kev
there should be a shell type bearing in top front off alko its the one under the red/green buttonand have had one thats caught the ball and grazed it it made the van hard to un hitch.
Thanks Crocky, as I go to work in the dark and return in the dark think I'll have a look at the weekend, Cheers
have you seen the insults on me crocs in yhe uk parks post about haven blackpool ,i meen slag me crocs of by a man that goes to haven black pool what next ,,glass lids for me pans.
Derek the Second said:
postman Pat crocs AND glass lids now that's a bit much
Its Forest, honest Derek he just keep on and on and on about those damm Crocks and now he keeps on about me Glass Lids,
which I aint got anymore!!
Let me borrow Teddy's gun seems the simple way out
See we've got him now he doesn't know how to reply
Derek wrote;
Thats it then maybe we will have some peace now, but then again he hasnt replied in the chit chat section yet.
Wait till he reads that
