TOD ? please define.Some kind of heat sink with a self setting TOD🤔🤔. New to me
Thermal Overload DeviceTOD ? please define.
Do you know the previous owner, they may be able to help.Thanks everyone for your time. Its off a 2006 Coromal Lifestyle 605. It is mounted adjacent to the charger in a cupboard, under a white plastic wall mounted box. Like a junction box. There is a 3 way fridge adjacent to the cupboard. Not sure if it could have something to do with that?
Regarding the purple wire, I noticed a purple wire connected to the drawbar anderson plug positive side. Im not certain that it leads to the purple wire seen in the images as its hard to trace but ill do some investigating with a multimeter. So at the anderson plug on the drawbar there is your standard black neg and red positive, and also a purple soldered onto the lug with the red. My thoughts were an independent power cable to the 3 way fridge? I just dont know if this little alloy block in the photos has anything to do with it. Its my first caravan and only just purchased so trying to wrap my amateur head around it
I have asked he has no clue unfortunatelyDo you know the previous owner, they may be able to help.
I agree concerning the high current, but I can only see two connections which tends to discount a thyristor which normally has three connections.Initial reaction was that the bulk of the block infers it is related to high some current carrying function?
And it does look like it has, and forms a mount for a Thyristor,
I have little doubt it is some after-market add on. Its nature implying it was a DIY job. that severed some now long defunct purpose the installed required, but now nothing.
Not that that moves you on in any constructive way, sorry.
How it is integrated circuit-wise, might help in understanding the purpose.
If there was a tendency for the voltage to spike every now and then maybe it could be a rectifier? Just guessing!Most of us get by without anything like it, so if I had purchased a van with it, the more so as installed here, it would be coming out and van put back to standard, at least if I could not find out what attributes it was bringing me.
A rectifier (incidentally a diode is a rectifier!) is often used in a fly back or snubber network to capture reverse polarity voltage spike that are produced when a current through an inductor is switched off. The circuit can "ring" as the magnetic flux field around the inductor collapses. Properly designed circuits that might have a voltage spike should also contain the snubber and not require one to be fitted externally in such an ad-hock manner as the OP's.If there was a tendency for the voltage to spike every now and then maybe it could be a rectifier? Just guessing!
