- Jun 20, 2005
- 19,964
- 5,261
- 50,935
Thanks BB
The answer to your fault code says
8 flash code on this scooter relates to a motor voltage fault. This means that the correct voltage is not getting to the motor from the power supply. This can either be caused by a bad harness between the power module and the motor or a problem with the motor itself. You need to measure resistance between the motor harness and intermediate motor harness this will determine which component needs to be replaced.
Hopefully it’s just a connection issue.A new motor sounds expensive .😢
There again the batteries may be dropping their voltage as soon as a load is applied
I suspect you will be treating your scooter to an expensive Christmas present.
Hopefully you will find out next week.
