Hi Karen, welcome to the forum.
Your caravan will usually have three sources of energy, lpg for the cooker and probably the heater, 230v mains electricity for the battery charger, some of the interior lights, plug sockets, the fridge, the water heater and blow air heating if any or all of these items are fitted, they may not be.
Some or maybe all of your interior lighting will be 12v, a 12v electric water pump and electric toilet flush if fitted will also work from your leisure battery.
Provided that your battery holds enough charge a 12v tv will work ok with a decent aerial connection. Look to see if there's a 230v plug socket near to where the tv usually sits, in which case a small portable mains tv would be fine (Aldi do a reasonable model for not much money)
There should be an onboard battery charger, quite possible a Zig unit which would charge your battery if it's working ok. Look for the unit under the seats or in lockers, and for switches that would turn it on and off.
Has your caravan got an electric hook up lead with an inlet socket point on the side of the caravan (ehu) ?
