Good luck with fitting it all neatly and I hope all the lights work correctly , with being on this forum I assume you tow a caravan so maybe you should fit the wiring to a 13 pin socket to make the system a little more future proof and give far less troubles with pin contacts/earthing/wire size . I know this may necessitate changing the caravan plug(s) to but I'm sure you will notice the benefits . Steve .
