Vectra towbar wiring.
Mar 6, 2010
71
Hi just brought a plug in towbar wiring kit for my 2006 vectra. Is it just a case of plug in and go. There's a wiring loom to plug in and a trailer module. I've found where they plug in. Cheers mark.
Mar 9, 2008
247
Good luck with fitting it all neatly and I hope all the lights work correctly , with being on this forum I assume you tow a caravan so maybe you should fit the wiring to a 13 pin socket to make the system a little more future proof and give far less troubles with pin contacts/earthing/wire size . I know this may necessitate changing the caravan plug(s) to but I'm sure you will notice the benefits . Steve .
