Venus Luner, Water System Repairs Ireland
Jun 3, 2024
22
515
Hi All,
we have a 2017 Venus Lunar 550/4 and the water system has stopped working, could anyone suggest a reliable place in Ireland ( north or south) that I could bring the caravan into to have it looked at?
5,585
Hi All,
Do you use a submersible pump in the aquaroll? It could have failed.
Possibly that simple. A new replacement is all that is needed?
Reactions: Thomas Dixon
Jan 19, 2002
1,711
551
Have you checked that the tap spout ends are not blocked - without more info it is difficult to know whether you need a cheap fix or something more major!
9,667
This might be the place to take your caravan
campingni.com
The link doesn’t show anywhere specific for the OP to consider b
Jun 3, 2024
22
515
Caravan Water System Issue – Lunar Venus 550/4 (2017)
Here’s what’s happening:
  • The submersible pump is running continuously and does not stop, even when no taps are open.
  • When I turn on a tap, water flows strongly at first but quickly drops to a dribble within about 30 seconds.
  • The water also sputters, as if there is air trapped in the system (possible airlock).
  • The pump appears to be working in terms of moving water, but something is clearly wrong with pressure or flow. Any help in diagnosing or fixing this would be greatly appreciated.
Any advice will be greatly appreciated and tried
22
515
I'm currently experiencing problems with the water system in my Lunar Venus 550/4 (2017) caravan. Here’s what’s happening:
Any advice will be greatfully accepted and tried
Quote Reply
5,585
Possible air entering the system via failed O rings at the inlet entry on the side of the caravan. Are all the drain taps correctly shut?
Whilst the pump motor is going maybe the impeller is faulty?
Jun 3, 2024
22
515
thanks, just checked and all the drain taps are okay, they haven't been touched , Ill check the O ring and replace it later see if that makes a diffence
thanks again fir your taughts on this
