C ColinA Feb 4, 2007 293 1 0 Jan 26, 2008 #1 The awning light on my 05 vermont has stopped working. the bulb is ok. Has anybody any idea where i should best look for the problem. Colin.
H Hamer_5041128 Dec 23, 2006 788 0 0 Jan 27, 2008 #2 An 05 Bailey caravan should be covered by the manufacturers warrany. Give your dealer a ring. If your caravan is near to it's annual service then your dealer should fix it. If not ask the dealer for any clues. Hamer
C ColinA Feb 4, 2007 293 1 0 Jan 27, 2008 #3 Thank Hamer I thought it was just one year warranty Colin,
W WatsonJohnG Mar 14, 2005 4,638 0 0 Jan 28, 2008 #4 Its 3 years on parts but have you checked the fuse There is a cover in the roof locker on the Oklahoma that can easily be removed to access wiring You could check voltage at the terminals using a meter or 12V test bulb
