Vermont awning light
The awning light on my 05 vermont has stopped working. the bulb is ok. Has anybody any idea where i should best look for the problem.
Colin.
An 05 Bailey caravan should be covered by the manufacturers warrany. Give your dealer a ring. If your caravan is near to it's annual service then your dealer should fix it. If not ask the dealer for any clues.
Hamer
Its 3 years on parts but have you checked the fuse
There is a cover in the roof locker on the Oklahoma that can easily be removed to access wiring
You could check voltage at the terminals using a meter or 12V test bulb
