Hi all
We got round to closing down and winterising our caravan this weekend 🙁 as we are fairly new to caravanning we have been getting a lot of tips off forums like this to make sure we are doing everything we can to keep our van in tip top condition ready for spring. For example cleaning inside and out ,removing all cushions and bedding etc opening all cupboards for ventilation removing battery and the list goes on. One of the main concerns was making sure we drained all water out of the system. On our last journey we drained our system and left open waste water outlets and the outlet for the water heater for the trip home. I then read about the Floe system for draining your caravan completely were you put pressure into your van to get out the last drops of water. Although I was a little sceptical about its claim of getting so much water out of your vans pipes, I went out and bought one, thinking if there is any water left in the system and we get a hard frost there would be a chance of frozen pipes and the problems that could cause. Well I have to say I am very impressed with this piece of kit, very simple to use and for a 20 minute job the results are brilliant. We thought we had completely drained the system however after using Floe we got out nearly a pint and half of water through our taps and shower and water that had black bits in it therefore old water that had been lying in the pipes. Sometimes you read about all these accessories and tools for caravanning, some you definitely don't need, some come in handy and some are worth investing the money in. I would recommend anyone to try Floe and you will be amazed with the results
