- May 8, 2006
- 2
- 0
- 0
I have a 2001 V70 Mk2 that I want to use for towing my caravan, my problem is that I need to run a wire from the alternator to a "Combi Master" split charging rely that is in the wheel well of the boot, this would activate the relay to charge the battery in the caravan and run the fridge whilst the engine is running.
I cannot find a way into the car from the engine bay to run the wire through to the boot.
Is there an ignition fed line in the boot fuse box that I could use to activate the relay or is there another way that I could activate the relay.
Many thanks.
Denis F Pipe
Many thanks.
Denis F Pipe
