Just joined the forum in the hope of some advice, basically I have water ingress which at the moment I am assuming is from a small crack in the front ABS panel of my 2019 Elddis Xplore 554 which I bought from new 5 years almost to the day. I had assumed it was the window hinge and or seal but have noticed the crack while trying to identify the source, which has caused a fair bit of wood to rot behind the front window seal, I understand now this is a common problem! I bought this Van hoping it would see me through until the end of my caravanning days but how silly was I, they are obviously even worse than years ago, at least my first Van made it to 15. Now, trouble is, I have not had the Van serviced annually - to be honest I am an ex-mechanic perfectly capable of servicing it myself and was daft enough to assume I could sort out the problems as they came along (it's a British caravan after all) and it basically wasn't worth the grief and expense and it would be fine for 10-12 years, yeah I know don't say it.....
Anyway, what I would like to ask is, is it worth even starting to talk to the Dealer? Last time it took them 3 weeks to provide a rubber seal that was completely missing from the washbasin which I only discovered on the first trip (so much for the PDI check) and apparently the end panels are now not covered by the warranty anyway even if I had had it serviced, so as far as I am concerned I should be covered by the Consumer rights Act 2015? Looking at other posts it seems the best I could get is some sort of repair, but even if the dealer agreed to replace the entire front panel, I imagine I am going to be liable for the work to replace the damaged timber. Fortunately it is only the plywood surround that has been damaged, I have cut out the affected areas and am quite capable of replacing it with new wood, and even more fortunately I can get to the rear of the crack from the void in the corner of the front lockers to repair the crack, hopefully. By the sounds of it even if they replace the whole panel it may still crack in a few years, so I seriously wondering if it is worth the effort of getting the dealer involved - having said that I am really disappointed with what I consider is a a design flaw or poor workmanship, probably a combination of both, and don't see why the dealer will assumingly use the fact I have not had it serviced to hide behind. I accept the damage may have been less (maybe not much depending when the crack developed) if it had am annual damp check, but it doesn't excuse the fact it's failed? Should we really be having to have damp checks every year on new Vans this day and age, this one was supposed to have a 10 year water ingress warranty after all, how can this be if the end panels are only covered for the first year? Any thoughts welcome, I have to say I will never buy an Elddis Van again.
