Washing caravan
We are looking for a fairly decent wash brush where the head doesn't continually swivel around every time you use it. Over the years I have binned at least two of these brushes. The brushes are okay for the first two or three washes and then the heads start swiveling so for now have given up on attempting washing the caravan. Extremely annoying. Granted the brushes were all under £20. As the brush is soft I have used it on the car.
Ideally I would like to snow foam the caravan, car or even conservatory, wash off the foam and then shampoo using the brush with a final rinse. It is easier for me to hold the brush than to hold a sponge and once the sponge once slips out of my hand onto the floor, it then needs to be binned. Obviously when the brush is compacted it should not be too long with the possibility of perhaps being able to carry it in the caravan front locker.
Any suggestions for a brush that does not go into swivel mode?
Can't really suggest anything but I have one if those extending brushes that connects to a hose.
Probably not what you're after, but the head on it screws in and would rotate round annoyingly during use. I just drilled a small hole in the head and put in a small self tapping screw. Been fine ever since.
I did the same as Sam to stop heads rotating, but my biggest gripe was that the water connections to the hose weren’t sufficiently robust particularly up a ladder doing the roof.
The one and only time I tried with the hose connected, I think I got more water on myself than on the caravan.
Or maybe silicone (or sikaflex) the brush head to the handle - but I agree with others it is the connection to the hose that is the most frustrating - so I purchased an oval bucket so I could dunk the whole head and lift to roof height even when on my steps!
Some folks use a “noodle”head mop instead of a brush and say it is much better. Don’t think you can use a hose with them and not tried one myself.
Basically it seems to be a mop head. I would avoid using one on a car or caravan as you may scratch the paint work with the head where it attaches to the pole.
I drive past my local fire brigade and stop in front of the doors, asking them if they wouldn't mind blasting it for me. I added some liquid soap beforehand 🙂
...satire
