Washing Line stands
Apr 25, 2005
22
Hi all,
We purcahsed a rotary type washing line last year, but for some reason it did not come with a stand. Does anyone know where we can get one of these stands, preferabely online somewhere.
Paul
Oct 17, 2006
1,489
Hi Paul, May I ask why it never came with the stand? You may find it difficult to find just a stand, they normally come complete, if it's one of the quite small foldable ones, you try a good camping accessory shop, might be cheaper to start afresh. Liz
Oct 17, 2006
1,489
It happens to us all, they are quite reasonable to buy complete so don't give up, you never know somebody might know where you can buy just the stand. Liz
Paul I have seen them for sale without the stand also, but it has a plastic tube with pointed end to stick into the ground. I have seen the bases on sale in caravan accessory shops.
Aug 4, 2005
1,204
14
19,185
I've seen a couple of people with these and they had temporarily removed the jockey wheel and were using the clamp to hold the rotary drier. Don't know if I would like to look out the front window at the washing though!
Robert
Feb 11, 2007
575
Hi Paul , as Liz say's they come with the stand.About the stand if you get one we found out that it is best to drill a hole in each leg and put a peg though the hole for stability, the other thing is do not tighten up the two large plastic bolts that hold the pole as we have found it just broke the bracket, you will see what i mean when you get one.
Feb 11, 2007
575
Feb 11, 2007
575
Feb 11, 2007
575
