Water filler on cassette toilet
Apr 24, 2006
59
does anyone use some kind of pump to fill the water storage vessal for the toilet flush?
i am tring to think of a way to fill it up using the existing pump and a long hose connected from the shower.
any tips would be welcome
937
I either use the shower which reaches if led out through the toilet window, or a small plastic watering can, which is easier.
Dec 30, 2009
1,662
I use a Plastic watering can minus the rose to fill up, keep it in the front of van all the time specific for that job
Kevin H
Mar 21, 2006
57
we use a 5 litre plastic bottle previously purchased holding water approx 90 pence. Again kept in front locker specifically for this task. takes vey little time to do. very light weight and saves using stored water.
May 30, 2006
70
Hi, I use a Plastic milk bottle, the sort you get everyday from supermarkets. I keep it in my front box, its light and easy to use and Free once its empty of milk
640
Hi Gary
We have an electric flush toilet and use a pump to fill the top tank. Inside the cassette compartment we have fitted a 12 volt 2 pin socket wired in to the flush wiring, we have an old whale water pump with 2 pin plug fitted to the wire, the hose goes in the top tank, plug in and it fills the tank. Previous caravan had similar system built in with a switch to control the pump, easy to do if you have the electric toilet, if you don't have the electric flush you can still fit a pump but will need to find a 12v feed.
Mar 13, 2007
1,750
hi gary
I use a old 5 litre water container which is perfect for the job, the tank is 20litre and needs four containers full to fill it but the good thing is the pink fluid can be pre-mixed first and it,s lightweight and important to a yorkshireman FREE.
colin
