Water leaking from 1998 Eddis Typhoon GT boiler
Oct 1, 2022
I have a water leak on my truma caravan water boiler it starts as soon as I switch on any tap in the caravan it is coming from the red plastic valve with the clear tube nothing going down the clear tube just lots of water at the connection onto the boiler.
I have replaced the valve but did not help
4,398
It may be a question of how you have assembled the new valve onto the heater.
This might help:-
View: https://www.youtube.com/watch?v=lCVDZdpEM38
If this isn't the problem then it might be the the hot outlet pipe inside the heater. having broken its seal with the hot water tank. This would require a replacement tank. Its recommended any work inside the heater be referred to a qualified technician.
Bearing in mind the age of the heater, I do not know if a tank would be available, but also there will be other age related issues and other parts may also be failing. A qualified techie should be able to advise.
