Water pressure in washroom
Mar 9, 2007
128
Could anyone tell me why the water pressure from the taps in the kitchen is fine, but the water from the taps in the bathroom is not much more than a trickle? How would I go about investigating and fixing this?
Mar 19, 2007
348
Hi Emmy, it might be worth trying to track you water pipes back to where they meet the kitchen pipes. It would not be the first time that I have come across them being trapped under/behind units from when the van was made. Once located releasing them can be quite simple providing you an get to the screws that hold the unit in place.
Emmy, is the tap in the washroom doubling as a shower head? if so then remove the gause filter in the s/head. Usually gets blocked with results of what you have discribed. Bazz.
Mar 9, 2007
128
Thanks Bazz. That sounds like a very possible cause, as it has gotten worse over a period of time. Thanks. I'll do that this evening. Emmy
