Water pump fuse location
Jul 20, 2025
Hello and thank you for the warm welcome. Starting to regret our latest purchase which is a swift accord 484. Water pump was playing up so I left it running for a few, later I came back to it and found out the water pump switch is no longer illuminated on the switchboard. So I'm guessing a fuse has blown. I've had up all the seats up. I've had the back of the fire checked where the fan fuses are. I've even pulled out the switch panel and I cannot find the water pump fuse for this caravan. Can anybody help please? It definitely isn't under the seats or an overhead cupboards.
Sep 4, 2011
756
466
19,135
Year of caravan would help as equipment changes over the years. Swift used Nordelettronica years ago , but later changed to Sargent so different consumer units
Reactions: toad a caravan
Jul 20, 2025
Sorry, that would help yes. I know it's pre 2010 and I'm guessing 2003 . I got stung a little on buying this. Guy have us the rum around, by the time we got to him I was checking for damp and structural, forgot electrics.
Sep 23, 2023
1,485
660
2,435
On image "year of codes" it is the 10th digit that shows the age on mine it's N,hence 1992,the codes can be found on the windows they start with S10_022955.JPG11_023013.JPG12_023028.JPG
645
516
1,135
The fuse block can be hidden behind the space heater , underneath the floor (removable) of the wardrobe, screwed to the side wall of the caravan. Not the easiest to get to . Also seen them on the front fire wall
