Hi, after a bit of advice if possible. My tourer is sighted on a new site which is serviced. I have used a whale direct water hose this weekend, for the first time, which worked fine but I have found that the pump under the seat (smartflo UV814) has started to drip leak, I presume due to the pressure. The next day I swapped back to the normal submersible water pump & aquaroll but the water won't flow through the taps properly now using this system, seems like it's just spurting with air even when I run it for 10/15 minutes it won't flow steady through the taps. Tried the direct hose again and the flow is great but back to the leak. Have I damaged the pump under the seat, which I have removed for inspection then fitted it back. Any advice is greatly received. Thanks.
