After using the van this weekend (2004 Lunar Quasar 525) I had found a problem with the main water pump over running/staying on.
Sometimes it happens after using a tap other times it just randomly come on.
It run to the point it forces water to leak out of the "inlet" on the exterior of the caravan.
. I suspect it might something to do with the water pressure switch I found under the seating, but I am not sure how this should be adjusted to the correct pressure? Its a simple screw in/screw out adjustment??
Thanks in advance,
Peter
Thanks in advance,
Peter
