Water pump
Hi all, got a problem with the pump. I have an on board system with a priming foot pump. Foot pump seems to pump water out of the tap, however when I switch the tap on fully and the pump kicks in it just sort of dribbles and pulses a bit. The pump seems very loud and screeches a bit and also cuts out sometimes and the only way to switch it on again is to turn the tap off and on again. I dont really know how the pump should sound as I have nothing to compare it to as this is my first van.
Martin - I am by no means the one to answer but a couple of things I've heard spring to mind:-
1 failure of the microswitch on the tap
2 Is there any water draining out under the van? If so may be a valve open in the water heater?
3 Its a faulty pump.
I'm sure more knowledgeable people will be along presently.
