- Feb 19, 2006
- 7
- 0
- 0
I have an Adria 502DK, which has a water container in the front boot. I remove the container to fill it with water then put it back in the boot (difficult when full of water). The filter / pump drops into the container and is conected directly to water heater inside the caravan. I would like to convert this over to a standard "UK" style system - using an aquaroll and external filter / pump. I have seen kits which will require me to cut a hole in the side of my caravan to fit the unit, from the outside I can then use an aquaroll. However, I am unsure how to connect up internally. I have a plastic filter / pump attached to the end of a rubber hose, I presume I remove the plastic filter / pump and connect the hose securely to the new unit. I have a single wire running alongside the hose - I presume this will hold +ve and -ve cables that I also connect to the unit, how do I know which is +ve and -ve ? any advice on doing this job would be appreciated...many thanks.
