Water surging 2008 Ace Morningstar
Jul 1, 2009
2,142
check the filtter gause at the end of the taps i found that a van i had would not pump and traced it back to the taps blocked.
Jan 10, 2004
17
Hi Keith
What a bummer . A new pump and all.
I am certain there is a blockage or serious air leak. Do you have a filter on the end of the water feed pipe or an internal in line one?
Do you get the same result with all taps and the shower , trying opening and closing in different permutations?
Where are you? Maybe a local "Damian " could come out to you tomorow??
Best of luck.
Cheers
Dustydog off for a pint.
I'm in North Wales, is that local????? Bloody hope so!
Jan 10, 2004
17
If you want an engineer to come and look at your van, have a look here:
http://www.mobilecaravanengineers.co.uk/mcea-find-an-engineer.htm
There will be one of the mobile guys near you who can help
FIXED!!!!!!
Thanks Damian for the link to the engineers phoned the nearest Glyn Williams on Anglesey he could not get out today but told me to remove the inline mesh filter and all would be fine ..... hey presto water to the taps!
THANKS to all that replied, all ideas were greatly received.
Anybody need a new Shurflo Pump.....I know somebody who has one... LOL
Thanks again
Keith
Jan 10, 2004
17
FIXED!!!!!!
Thanks again
Keith
5,558
Good news Keith
Keep the new one as a spare. You never know!!
Enjoy North Wales. At SWMBO can shower now.
Cheers
Dustdyog
Mar 10, 2006
3,274
47
Keith
A good result in the end. As a matter of interest is the inline filter on the end of the hose? or inboard piped in?
Damien
I saved the link also. But i have to say having checked the engineer for my area, i actually used him for a home service 2 years ago, still have the paperwork, he is the EXPERT that bent the bottom of my alko chassis by not jacking at the approved point, he jacked under the two bolt holes that are used to secure the alko jack bracket, if fitted. This resulted in the bottom lip being only slightly bent up, but none the less its damaged. Also this same expert did not adjust the brakes after replacing the brake drums. It makes me wonder who actually checks there work, and if the checks are effective.
Jan 10, 2004
17
The inline Shurflo filter.
If you have a carbon filter fitted to your uplift pipe in the aqua roll surley there is no need to have the shurflo filter?
Keith
