Mar 13, 2008
10
can any help with bad tasting water i have a lunar gemmeni does it have a water filter fitted to this van (2001) i have flushed my barrel out several times but still the water tastes stale i have also drained the system down too.
Dec 6, 2007
414
Hi again Kevin!
I don't know about a filter in a Gemini but i'd be supprised if it hasn't got one somewhere, mine screws into a hole just above the water inlet [1994 Elddis]
On Coaches we used to flush the fresh water systems with Milton bady bottle cleaner , mix it up in the fresh tank and such the whole lot through the system. then suck a full container of clean water through to rinse it out.
Worth a try.
Gareth
Jun 16, 2008
43
I had the same trouble with yucky tasting water a couple of weeks ago and I put 8 milton tablets into a 40 litre aquaroll left overnight washed it out the next day and it was perfect. I think I will do this every 6-8 weeks just to keep the water tasing ok.
Aug 1, 2007
462
We do not use water out of system in van for drinking
We use 2 x 5 litre containers fetched from the tap for
tea/coffee and cooking
But all other water uses comes from system
Apr 22, 2006
369
Kevin you say that you have flushed the system through but have you replaced the filters themeselves.
These need to be replaced periodically and I think if something like Milton has been flushed through them they loose their effectivness.
Aug 24, 2007
139
You shouldn't leave the filters in when flushing out the system. Disconnect the actual filter from the screw-in bit and just use the screw-in bit. Ken
