whale filter ?
May 9, 2015
120
i have a whale filter on the end of my water supply that goes in the aqua roll the thing is its just to big to fit in ,,can i buy a another filter (smaller) or do i have to buy a new aqua roll with bigger hole ?
think its called aqua smart ?
4,160
1,890
Do you actually feel you need a filter there at all?
At best located as it is in the suction line they can provide only a "strainer" function, filtering out just large bits of debris that with a decent level of "house-keeping" ought not get there in the first place. They certainly will not stop a whole load of mirco contamination.
5,512
We have an on board pump. The 40 litre aquaroll feeds the inlet pipe which has whale aqua smart WE 3000 filter. Never had any problems with fit. If I remove the filter the inlet pipe tends to curl up stopping it sucking water from the aquaroll lower level.
What model of filter and aquaroll are you using ?
May 9, 2015
120
hi its a we 3000 filter ,,,i have two aqua rolls ..one it fits the other it does not the hole is to small ,,if i make a little mesh thing that i can fit on the end of the pipe it might keep it in the bottom ?
5,512
Rob
Are they both 40 litre aquarolls?
So you have an onboard pump?
Yes you can put a mesh or stocking or muslin on the end but you will also need a weight to keep the inlet pipe at the bottom of the aquaroll.
The carbon filter does filter out a lot of nasties so I'd prefer to keep it. However if you source your drinking water externally and use the aquaroll water for washing etc I don't see a problem.
40 litre second hand aquarolls are freely and cheaply available.
May 9, 2015
120
yes both the same size but the holes are different sizes ,,,yes it has an on board pump ,,and i never drink water from the taps ,,,
