Whale Heater Not Working
Oct 26, 2023
Hi whale heater not working I check flues and done reseat noting happening what else can I try
Jul 19, 2021
615
426
5,135
looks like we now have two threads on this, not including the original post in the new user welcom thread o_O
Are you running on gas or electric?
I only run on electric and have had this fault on a few occations when there is a high wind, or the wind is blowing in the "wrong" direction ie up the exhaust pipe.
I have a work around to place my aquaroll near the exhaust to shelter it from the wind. Turn off everything at master switch and restart everything.
It's yet another reason why my next caravan won't have a whale i-van system
NB, don't block or obstruct the exhaust if you are running on Gas!!
2,391
There are reset buttons for the heating and hot water on the actual Whale heater under the front bench. Two buttons, one for heating one for hot water. Try pressing those. Check your manual for locations.
We had a similar problem when there was a strong wind blowing into the outlet. Like Bluetonic said a barrier that does not block the exhaust but does shelter it from the wind was helpful.
