- Jun 20, 2005
- 20,329
- 5,505
- 50,935
BaileyNiggles said:I know, certainly on our caravan, there's a five amp fuse for the water pump, but does anyone know the maximum current the circuit could in fact take if a more powerful pump were fitted and the fuse uprated accordingly? Whale are playing dumb on this, answering my question by simply giving me a link to a PDF download about their range of pumps and then ignoring the follow up email pointing out that wasn't the question!
More generally, out of interest, is water, heating and water heater all switched within the Intelligent Control panel and if so how (relays, solid-state relays, power transistors, or are there relays hidden away somewhere under seats or somewhere else perhaps?)
Back to basics.
Is your pump the submersible type in the aqua roll?
What is the wattage of your original and the one you propose.
Two caravans back I did upgrade the submersible pump which was 11 Watts more the the original. I didn’t change any of the wiring or fuses.
There is a built in tolerance but you still need to know both the fuse rating and wiring maximum.
There is a school of thought that says the manufacturer of the upgraded pump knows the standard wiring can take the extra current. But please do check yourself first
