Whale internal pump strainer leaks all the time
May 22, 2024
13
I have fitted 2 brand new whale internal pump strainers and both leak when waters connected I just don’t understand thinking maybe I should just not bother having it.
Jun 6, 2006
866
164
18,935
Where are they leaking from?
If it is what they plug into the then it could be the O ring in the female part of the fitting
May 22, 2024
13
Hi I think I’ve worked out what’s wrong I have the caravan plugged into the mains water via a whale connection kit from the caravan to mains tap and I think this is causing too much pressure causing the leak I think I need to just go back to a aquaroll instead. 👍
4,704
Probably yes but also no. Follow Martin’s advice and change the O rings on the socket.
2,940
Direct mains connection needs a pressure limiter included - the Truma direct connection kit includes that as standard.
