Hi
I have an Elddis 868 2023 when I’m all connected to the water the Whale outside pump wants to eject from the socket on the van, the sliding cover holds it in place and stops it from doing so but it isn’t right
I can confirm the pump is pushed in correctly, I have reset the IC by following an online guide, I believe this to also be correct, however when you call for water the pump delivers as required, after shutting the tap closed the pump continues to run for a few seconds after all be it slighly faster, it is at this stage the pump pushes out of the socket at the bottom, this now breaks the water seal and i get water seepage from the socket, the pump continues to operate when required but its not sat in the socket correctly, the pump is relatively new and i wouldn't think it could be the rubber o rings inside the socket or could it
any ideas im at my witts end
Gavin
Gavin
