Reposition the pump. It sounds as if it may be turning back on itself. You need to make sure its suction stays near to the bottom of your Aquaroll. Some users place a small weight on the pump. I didn’t find that necessary as I could get it to keep in position.Hi, after moving from a motorhome to a caravan, I am for the 1st time using a Whale water pump. The problem is it leaves a good few gallons in the Aquaroll which means I am only getting 30 to 35 gallons of water.
Is this normal or do I need to adjust how I position the pump?
Paul
It has 40 ltrs on the side of itThe aquaroll only holds 40 litres?
Thanks I was putting the pipe all the way inOnly insert it in the Aquaroll so it rests upright on the bottom.
Are you using the Aquaroll upright or on its side. If the latter, try the former.
I look into weights, thanksReposition the pump. It sounds as if it may be turning back on itself. You need to make sure its suction stays near to the bottom of your Aquaroll. Some users place a small weight on the pump. I didn’t find that necessary as I could get it to keep in position.
Some use “pipe snap” but not sure it’s compatible with drinking water standard pipework.
Correct so not sure how it can hold 35 gallons? LOL! 😀It has 40 ltrs on the side of it
May be he's using an Aquaroll mains adaptor 😉Correct so not sure how it can hold 35 gallons? LOL! 😀
Ah, yes typoCorrect so not sure how it can hold 35 gallons? LOL! 😀
As we both know Dusty Dog, our Waste Masters, hold well over 40 liters with the Cricklade, vent cap. 🙈😏😏May be he's using an Aquaroll mains adaptor 😉
