spider1 said:Hi
Help needed what do all these switches do?
Some seem the work light, but not sure what rest do?
So here are the little panels
Panel 1 Do you have a on board water tank?
Panel 2
240v Mains on-- Should lit when EHU plugged in
Towing 12v Fridge on--This should light up when plugged into tow vehicle with I assume the first black rocker switch set to Car Battery. switch back to caravan when on site
Battery Charging---- Should light up on EHU
Battery Reversed polarity---Dont know
Panel dim---For night and day
Panel 3
Ext pump--again would assume on board tank
Awning light--normally outside above/near door
Reading light-=dont know, have you got a lught above the bed area?
Interior lights--does what it says!!
Water pump--switch on and when you turn on taps the green light should light up
Panel 4
Fuses.
Panel 5
Battery voltage indicator, this is only a guide and sometimes not accurate.
Panel 6
Dont know-- sorry
Thanks for help.
All the above are assumptions and hope they give you an idea, unless someone has had the exact one I'm afraid it is a process of elimination but would think most are pretty good guess's. Good luck.spider1 said:Thanks
Still unsure of some stuff
Spider, first question, do the black rocker switches have three positions, ie; your photos show eitther up or down, do they sit in the middle position?
Middle switch does what? Switches battery on and off?
Green LED means what 12 volts from Battery? Means there is a charge in the battery
Red LED means what low/ flat battery? Looks like and this is an assumption you have two warning signals to tell you that the battery is low red LED and the volt meter in photo three.
What is an ext pump? Yes i have got a tank (it needs to be bigger might put another tank beside it)
The ext tank is then an on board tank and the ext pump will be in the tank, others will tell you how to fill it via the aquaroll if you put a separate question in technical, I have no experience of a on board tank
What is the switch for next to volt meter?
To switch it on and off!
Thanks again.
