Hi all,
Having recently experienced a puncture, on site thankfully. I had the tyre repaired as a temporary measure. Cant sing enough praise about my KoJack, absolutely brilliant.
I fitted the spare no problem and travelled 150 miles back home, only to discover, I know, I should of checked, I assumed it would be correct, that the spare was a different tyre to the OE ones fitted, the max load was a lot lower @ 600kg instead of 650kg also the max pressure was significantly different, 44 psi for the spare, where the original was 55 psi, the spare WAS supplied by the main dealer.
Quite clearly this is not correct and I need to change the tyres. But what do I go for? My Bailey dealer is quoting £100 inclusive per tyre for the OE TrailerMaxx 185/65/14 6ply Reinforced and a 28 day delivery wait!!!!
I am very safety conscious and want to buy the correct tyres, so I guess you get what you pay for. But even the OE tyres seem a bit close to the mark, max load at 650kg each gives a total load of 1300kg at max pressures of 55psi. My van is a 2006 Bailey Ranger 550/6, MTPLM is 1298kg.
I have read a few threads regarding Matador, Khumo and Hankook aren't these budget brands?!?!? I realise the tyres are only on for 5 years and probably only a few thousand miles, but budget aint for me!
Can anyone offer any advice or recommend a particular tyre and supplier in the Derbyshire area?
Thanks in advance
Cheers
Gazza
Thanks in advance
Cheers
Gazza
