- Jul 15, 2008
- 3,899
- 1,084
- 20,935
Since most drum brakes are now fitted to higher mileage and heavier commercial vehicles....I think you will find that they are serviced by the easy removal of the drum in the manner I described.
Lighter vehicles, including private cars, usually only have drum brakes on the rear axle, if at all.
The braking bias is to the front disc brakes and usually means the rear brakes are good for around 40-50000 miles before anything other than inspection is needed at service points.
Drum brakes in these applications and caravan drum brakes do not need constant stripping down unless a fault is detected.
They may well have a similar arrangement to Al-Ko in that the bearing has to be disturbed to remove the drum
...My point was that this type of design is not supposed to be constantly stripped down.
