Wheel clamp disaster
Feb 9, 2009
465
24
18,685
Went to get the caravan out of storage on Thursday and the key just turned and turned in the wheel clamp lock. It is the big a Milenco with concrete in the legs so I knew that there was no way I would get it off. Had to call out a locksmith who charged £78.00 to drill out the lock.
Having seen how easy it was for the locksmith to drill out the lock I purchased a Purpleline Nemesis which the box said could be fitted in 60 seconds. I gave up after 1 hour the first time I tried to line up the bolt and again after 45 minutes the second time. The third time I succeeeded after 30 minutes and on the fourth attempt I succeeded after 15 minutes. If 15 minute reduction continues for the fifth attempt I may succeed in the 60 seconds claimed.
The Milenco was not easy to fit but the Nemesis is something else. Any one any tips for fitting the Nemesis ?
I will ask Milenco if they will sell just a lock so I can fit a new one to the wheel clamp and then sell the Milenco but the cost of the lock may be more than I can sell the wheel clamp for
Apr 7, 2008
4,909
Hello Mike
Well i supose if i had not got a bit stuck with the mudflap & the allen key slipping it would be quite easy......
Sproket in action
Now that you have got it fitted, what i do is remove the lock & then put the allen key into the bolt that is behind it turn it aprox twenty five times pull & lift at the same time & my first part lifts clear, & then just unwind the bottom bolt enough to slide the bottom clamp clear of the wheel, you do not have to remove the bolts fully each time you use it, I have coated the threads of mine with copper slip, you will soon find the way that suits you best.......
May 15, 2007
471
I have also got a Nemesis and can get it on ok now. I got a long alan key , cut it so it was straight then ground one end so it fits in my electric drill, saves all that winding in the screw. I wouldnt use copper slip, that just stops things sticking , just use a good grease.
Mar 2, 2010
1,231
6
19,185
wow just watched Sir Sproket CJ ( BAR) video,it makes the Alko lock look a dream and it almost fits in my pocket compared to the Nemesis,
