Wheel nuts
Hi all. About to go on my second ever trip now, and just realised that not only have i not checked the torque on the wheel nuts, I don't have the tools to do so. As the 'van is stored away from home and I can't check the locking wheel nut drive for size, quick few questions :-
( before I buy i torque wrench )
1. Is the drive size generic for modern wheels ( 2015Bailey pursuit) i.e. 1/2" or 3 /8" more likely ?
2. Anyone use the bright yellow plastic 'wheel but indicators ' you see on trucks and busses ? Seem like a good idea for just a few bucks.
For the amount of torque you will want a torque wrench with a ½" drive, a ⅜ one won't be man enough. As for socket size probably 17 or 19mm
As for the yellow "tell-tales" they won't fit because of the design and profile of your alloy wheels. They will only fit wheels with a flat (or proud) face, not a recessed one.
Bailey generally use WSL wheel bolts that would require the correct adapter, this requires a 19mm socket and is set to 130 NM and 1/2” drive torque wrench
