The caravan Alko stabiliser hitch was 100 kg max but the limiting factor was the nose weight applied to the car towball and this was 80 kg. maximum.As you had a 2013, what was the advised Tow Ball weight?
You need to understand that there are two limits. The caravan chassis through its hitch load has a maximum. The car via its towbar also has a maximum. Swift do not get involved with the loading onto the cars tow bar only the loading onto the caravan. Ford set the cars limit. So in your case the prevailing limit for the outfit is the cars 90kg.Thanks again. I have a Kuga and it's hand book states 90 kgs and swift say 100 kgs, so 80 kgs sounds good to me.
Thanks again.
???? Are you talking about the OP nose weight or yours i e 90kg ?We always like to have our caravan nose weight as close to the maximum figure i.e. in this case 90kg as it feels like a better tow. Our current caravan is rated for 150kg and we have the caravan nose weight at 145kg for a comfortable tow.
It does muddy the waters but the OP car can take 90 kg and the caravan max is 100 kg. So lowest prevails.???? Are you talking about the OP nose weight or yours i e 90kg ?
What is your current car nose weight?
Sorry I don't understand!
Apologies I have modified the post so that it reads a bit better.???? Are you talking about the OP nose weight or yours i e 90kg ?
Please . Be pedantic😉Nose load🙏🏼🙏🏼Here we go again about Nose weights. 😂😂😂
I shall Get mi coat. Enough said. 🤞 🤞 🖖Please . Be pedantic😉Nose load🙏🏼🙏🏼
