Where are fuses on1998 Elddis Hurricane GTS, please?
Water pump (Whake type with hose etc attached) works when connected direct to battery but not when connected to van. I've cleaned connections but no luck. Ray suggested the fuse.
Wiring diagram has 10A fuse but I can't find any fuses.
Can anyone tell me where they are or likely to be, please?
Thanks, Wes
It will be either a blade fuse or a glass fuse located in or near the power supply unit, depending which supply unit is fitted.
