Which 12v tyre inflator ?
We have a Von Haus. Make sure whatever you buy will give you the bar you need for your caravan. I've had the Von Haus for 2 years and it's just started playing up, so I may try something else.
I have a new Michelin which works just fine and goes well above caravan tyre pressures. But to be honest for years I’ve mainly used a cycle track pump as I’m only adjusting a few psi. But family come around to show me their TPMS light is working, so they use the Michelin one more than me. A powered one (older Michelin ) was useful on site when I had cars whose solo and towing pressures were quite different.
I have three😱
Old standard VAG blue one ✅
AA branded one ✅
Battery powered cheap one similar to This
All work for top ups, the battery one is not good at pumping caravan tyres up from flat. However day to day I tend to use the battery one unless the tyre is flat.
I just bought a ring type with digital display, its the ultrainflate 20 , and is very good with a clear display and preset pressure setting and good cable and hose storage, however it takes about 12A and it took out my cars' atc fuse for the cigar lighter socket so I had to uprate it to 15A and changed the socket/plug for the DIN ISO 4165 type, a bit naughty but given the infrequent use it will get it will be fine . I have also fitted the same type outlet socket rated at 20A on the caravan's side to power various 12V devices in awning .As I use the pump a lot when working on caravans I have fitted the 20A connector to it and run it off my 280 A.hr battery /inverter system which I use to run caravan 240V systems. and also test the road lights I found the standard 12V connectors poor quality and get very hot when running at about 5-10A.
My VW-supplied inflator uses crocodile clips on the "battery" posts in the engine compartment - seems a better arrangement for higher-powered inflators rather than the limited current of a cigarette-lighter socket type.
I have two Chinese Nonamee from Amazon.
One looks like a hairdryer and has an integral Li-Ion battery. Simple to use
Set the pressure and squeeze the trigger twice. Auto shut off and it remembers the setting when powered off. Has a light on it that shines towards the valve.
The other is like a brick. In built battery but also can run from a 12v aux power connector. Has too many modes and doesn't remember your setting when powered off. Goes back to default which is not the pressure I need when switched on.
Display hard to see in bright daylight. I only kept it because of the 12v power option.
Junked a number over the years as I suspect the caravan's 65 psi has been more demanding then they could take. All in early life managed but with wear lost the ability, at least in the time scale I could tolerate waiting for them to lift from say 62 to 65 psi. Most I suspect are aimed at the normal domestic motorist market, where tyre pressures rarely exceed 40 psi.
After those failures, and we are going back many years I found for that odd few psi correcting back to 65 psi, my quality cycle track pump worked a treat. That I carried anyway for the even higher pressures of the road bikes we rarely travelled without, so an ideal solution, bikes, vehicle and van all covered. Bigger inflation issues like with roadside fitting a new tyre to a rim, is for me a job I pay my roadside assistance service to undertake.
At home where I have had way more serious high air volume inflating tasks than the few psi correction encountered away from home I purchased a Ring 900. This is a significant lump of a thing, not what I want to be carrying in the boot, just in case. Plus its not low powered so able to use a automotive 12 VDC outlet with that's 10 Amp limit; this can pull up to 30Amps so is connected normally by clipping directly on the the battery posts.
I was motivated to get this as it was what one of the recovery service vehicles that came to us carried, and the mechanic had recommended.
I can't help you. I have had this one for years and works well. You appear to be asking fir recommendations for one that doesn't work.
Looks to be what I have and was back then sold as a RING RAC900.
I have found it does all I ask even many years on. It was what the roadside assistance van had, I seem to recall it was an AA service van, and I assumed was part of their outfit back then.
Importantly, its unsuitable for use from a standard car 12 volt socket as it can pull up to three time the current these are wired to provide.
