Which make model to consider Motorhome Family 2 adults 2 kids
Dec 6, 2024
14
10
Thats an interesting set-up, and looks like they have got everything covered. I take it they give you a hands on demo when purchasing? If you are set on a MH, looks like the way to go (y) (y)
I would imagine they do and from what I’ve read they are very helpful
They even have cars for sale that already have their A frames attached to them if you look at the drop down menu
Jun 16, 2010
383
168
18,735
My towed car uses an electronic braking system.
Quite a snazzy piece of kit - it runs a vacuum pump to charge the brake servo and operates a piston to depress the brake pedal. All proportional, based on an accelerometer in the control unit.
Some of those mechanically operated braking system merely feed a cable through the floor to tug on the brake pedal.
2,475
Don’t pay VED on a small 1.0 petrol but I get your point 😂
Why was it a hassle….seems a lot less of a hassle than a caravan and car?
My friend got a Motor home he uses a A frame with his Toyota Aygo 1.0 he finds it lot easy to tow then a caravan .
648
296
1,135
Seen Suzuki Jimny being towed on single axle trailer. May have had legs/stays to help with loading loads. Big advantage with this setup was no need to mod vehicle and any light small car can be used. Owner had towbar on Jimny so it could tow trailer if need be., eg tight roads and camp sites.
NB most cars can't be towed without lifting drive wheels off ground. This is why Jimny is so popular.
2,475
Is he towing a caravan behind the MH? I doubt if any Aygo could tow any caravan? :unsure:
He use tow a caravan with his car and he change it to a motorhome and now got a Toyota Aygo what goes behind on a A frame system ,:D
4,939
He use tow a caravan with his car and he change it to a motorhome and now got a Toyota Aygo what goes behind on a A frame system does that answer your question
That make sense as confused by your original post. (y) :)
