Why does my motor mover need to have the 13 pin plug attached to the caravan
Jul 10, 2016
16
Hi
I have just been away on a site and when I tried to use my motor mover, the remote switched on and made its clicks as normal, but didn't engage the relay. Having looked on line, it might be that the mover is in lockout.
However I also noticed that the 13 pin plug didn't seen to connect when I pit in back on the caravan towbar socket. It connects perfectly to the car, but not to the caravan. That got me thinking. Why do we need to connect the plug to the caravan towbar socket to run the motor mover, shouldn't the mover just run from the leisure battery. I am just struggling to understand what the point of the towbar socket on the caravan is for. If i just disconnected it from my car once towing complete and then just left it unconnected from the towbar pin socket what would that result it??
Sorry of this is a daft question, just trying to understand how the 13 pin towbar socket works and why my motor mover doesn't work now
thanks
4,841
I am confused about your posting, on the vans I have had I just disconnect from the car an the MM runs from the caravan battery.
What caravan do you have.
Jun 6, 2006
1,040
260
19,435
If it’s a Truma mover then there is normally a socket on the A frame like the 13 pin car socket, only the one on the A frame will have two linked pins to make the circuit on the Truma PCB
Reactions: Jcloughie and Hutch
Oct 19, 2023
639
510
2,135
I don't have that system on my caravan, but my best guess would be that it stops you using the motormover while the caravan is plugged into the car.
