oh i wish it was 1400kg in uk,its on my company car list to replace my very good mondeo which has a max tow of 1800kgIt seems strange that the UK VW website quotes 1200kg as the maximum towload for the BlueMotion whereas the German one states 1400kg for the same car. In both cases it is still lower than comparable models. I speculate that this is due to improvements to the aerodynamics of the BlueMotion having been achieved at least in part by reducing the airflow through the engine compartment. This could result in an engine cooling problem with higher towloads.
It may be worth raising the issue with VW and asking them for an explanation for the difference. With a bit of luck you may find that it was a typo error in the UK data.It seems strange that the UK VW website quotes 1200kg as the maximum towload for the BlueMotion whereas the German one states 1400kg for the same car. In both cases it is still lower than comparable models. I speculate that this is due to improvements to the aerodynamics of the BlueMotion having been achieved at least in part by reducing the airflow through the engine compartment. This could result in an engine cooling problem with higher towloads.
