Hi all I am trying to replace my kitchen window handle but cannot replace it,There are no screws but there is a pin in the handle have tried everything to remove the pin is there a way to remove these thanks mike
If you have a close look at the handle, you will see a small hole. If you insert a small screwdriver into the hole it will release a spring-loaded lock. Whilst pressing this, the handle can be slid from the mount.
