Iest said:Just had the van (Swift Conqueror 2013) serviced and there seems to be a little damp around one side of a front window. Suspected leak form the seal. Obvious cure is a new seal but is there a way of running a sealant under the rubber seal until I get the rubber seal replaced. B)
otherclive said:Iest said:Just had the van (Swift Conqueror 2013) serviced and there seems to be a little damp around one side of a front window. Suspected leak form the seal. Obvious cure is a new seal but is there a way of running a sealant under the rubber seal until I get the rubber seal replaced. B)
Given the age of your caravan is it covered by Swifts water ingress warranty? If so your dealer could effect temporary repair until the warranty repair is undertaken. I wouldn't worry about sealing damp in. Mine has a crack in the top O/S of the rear panel which was at 30% when serviced in December. It is sealed with waterproof tape until new panel is fitted under warranty. If you stop water from getting in, I doubt that there are are many places on a caravan where it wouldn't begin to dry out with time.
Buckman said:otherclive said:Iest said:Just had the van (Swift Conqueror 2013) serviced and there seems to be a little damp around one side of a front window. Suspected leak form the seal. Obvious cure is a new seal but is there a way of running a sealant under the rubber seal until I get the rubber seal replaced. B)
As it is a 2013 it should be covered under the Swift 6 year warranty. I think Swift actually have a 10 year warranty in place if the same owner since new?
