The measurement of the seals is the overall width of the opening the window sits in from inside to outside of the window opening.
You could lift a small bit of the seal where it joins and measure there, or if you have a good eye estimate where the body starts and finishes.
For the length you require measure the whole way around the window opening and add about 4 inches to allow for any mistakes in fitting.
